Massey Ferguson 65
   / Massey Ferguson 65 #1
kluce
My dad's old 65 will lift the 3 point, but has no power, It might lift 100 pounds or so, Gets worse as it warms up. Any sugestions??
thanks, KL
   / Massey Ferguson 65 #2
:welcome:
Can you fill in some of the blanks for us. History? When did it start? All of a sudden? What has been checked out already? etc.
Pump would be first suspicion. Run some pressure checks to help track the problem.
   / Massey Ferguson 65 #3
Make yourself a hyd pressure gage tester and check out the system. Seals could be leaking.
   / Massey Ferguson 65 #4
Most of those MF65's use 80- 90 Wt gear oil for hydraulic fluid... If you put anything with a lighter viscosity you will have the exact problem you are having until you drain and replace the fluid. Also when changing the fluid there is an internal filter that can get clogged up, remove it and wash it with diesel or kero... While at it do not over look the final drives, they have planetary drives on each axle that must be drained and filled. (will not drain with hydraulic system) MF65 is a wonderful utility tractor. KennyV
   / Massey Ferguson 65 #5
yep.. pressure test it.. and look for leaks from the piston bore.
post back.
soundguy
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
2014 Landoll VT-Plus (A52349)
2014 Landoll...
