Negative on the clutch
its a pretty common occurance on early MF tractors a mf 35/to35/mf50 are similar
next to the shifter is a large plug. remove the plug and you can see inside. The best I can explain is to use a large screwdriver and try sliding the gears around to free it up. It will work , it will take some time, it will frustrate the heck out of you. This is assuming it was working correctly before it got stuck.
on my old mf 35 this happened several times and I always got it to function....use the search function and maybe you can find a better explaination.
good luck
