Massey Harris 50 throttle Linkage
   / Massey Harris 50 throttle Linkage #1
lskalicky
MH50
My MH 50 throttle does not let the engine rev up very high. it was operating perfectly, I shut it off and was unresponsive when restarted it 5 minutes later.
Engine will rev if I open the throttle a little at the carburetor manually.
The rod going from the carb throttle to an arm at the front of the engine does not move. Any suggestions to repair or where I can find a diagram would be much appreciated. Thanks
   / Massey Harris 50 throttle Linkage #2
I have the same problem on my MF-50, did you figure anything out with it?
   / Massey Harris 50 throttle Linkage #3
I'm not at all familiar with that tractor, or governor. That being said, on my IH tractors, that is usually a sign of a broken spring, or bad thrust bearing in the governor assembly.
If you don't have a service, or parts manual, go here: AGCO Parts Books When the page opens, click on "view books" in the lower box, beside where it says guest user. On the next page, type in 50, where it asks model, then select Massey Ferguson from the menu at right. On the next page that appears, select MH-50. On the next page that appears, scroll down to page 38, throttle, choke, and governor, and click on it. An exploded view of the linkage, and gov. internals will appear.
There are two springs showing that could be the culprit. Hope this helps.
2003 Pierce Spartan Pumper Fire Truck (A54814)
2003 Pierce...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A55745)
2014 AMERITRAIL...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
