McCormick baler model 46 pickup will not turn
   / McCormick baler model 46 pickup will not turn #1
rmjmbsith
I have a model 46 baler that the pick up will only turn a quater turn then stops. I can't see inside whee the pickup turns. I can't tell if something is bent or off the track. Any help would be appreciated. Thanks
   / McCormick baler model 46 pickup will not turn #2
Could be that the track is bad. You will have to remove a stripper or two to see more then likely.
   / McCormick baler model 46 pickup will not turn #3
So the baler turns but the pick-up doesn't? Did you check the shear pins? Not familiar with McCormick, but it should have shear pins or a clutch somewhere.
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2019 RBR Venturi 380 (A52128)
2019 RBR Venturi...
Toyota 6FGU25 Forklift  5,000 lb Capacity (A52128)
Toyota 6FGU25...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
