Meg-Mo Blades?
   / Meg-Mo Blades? #1
Mayhem
Bronze Member
Ransomville, New York
BX2200
Anyone use these before? /forums/images/graemlins/confused.gifIt looks interesting,I may have to check into this further.Has anyone had any experience with these?
http://www.meg-mo.com/
   / Meg-Mo Blades? #2
Rich,
I have used them on my 72 inch deck and like them. They do a nice job of mulching. They even do a fairly nice job in wet grass, but I try to avoid mowing wet.
In my opinion, they are a fair and reliable company to do business with.
JackIL
   / Meg-Mo Blades?
Thanks JackIL:
@ about $225.00 for the set I need to have someone say they work /forums/images/graemlins/smile.gif
I don't have any leaves to mulch, I'm just always looking for a better cut.
I want to put a Striper attachment on so I'm thinking that anything these blades might do for a nicer cut would be messed up by the striper /forums/images/graemlins/confused.gif
Rich
   / Meg-Mo Blades? #5
Rich …
I use a set on my 6’ finish mower… This is my second set.
The first set was not very good, I contacted the guy that makes them. He checked & found there was a mistake made drilling the first.
He sent me a second set. With that set I discovered the 12 blades had so much lift, the air blowing under the deck tended to push the grass down, this resulted in a rather uneven cut.
With some experimenting I found that by replacing every other blade with a flat (no lift) blade, disk mower blades. Cuts and mulches very well.
It is a heavier load on the engine… mulching after all is re-cutting the grass. I probably do the majority of my mowing with the original manufactures blade.
MegMo is a solid company and he will try to resolve any problems. Seems some decks will handle the double air flow better than others. KennyV.
Farm Hand Silage Wagon (A50515)
Farm Hand Silage...
2000 Trinity Built Trailer (A50514)
2000 Trinity Built...
1990 HOMEMADE LOWBOY TRAILER (A51243)
1990 HOMEMADE...
TMA (A49461)
TMA (A49461)
2018 Ford Escape (A50324)
2018 Ford Escape...
NEW HOLLAND L180 SOLID TIRE SKID STEER (A51242)
NEW HOLLAND L180...
