meteor snowblowers on a Kubota
   / meteor snowblowers on a Kubota #1
design
Southern, NH
M5400
Does anyone have a meteor snow blower? Any issues? How much was it to buy?
-design
   / meteor snowblowers on a Kubota #2
Last winter I bought a used (about 10 yr) 60" meteor to put on my B7800 for $650.00 CDN. I think it throws the snow about 20 ft but might throw farther if I adjusted the chute differently. 20 ft works O.K. for me but I've read where some people have theirs throwing 50 ft. The gap between the fan blades and the fan housing is about 1/4" so if you got one where this tolerance was closer it might throw farther- don't know. I don't have any issues with it - works fine for me. I just have a manual chute rotator but being on a small tractor I have no trouble reaching it from the seat. It seems like the snow wipes the chain lube off of the chain that drives the auger about as fast as I can put it on so I might look at putting some sort of guard over the chain to keep the snow off it, but it hasn't caused me any trouble so far. I wasn't prepared for the fine snow blowing in my face if the wind changes, so a balaclava is necessary if you don't have a cab. Somebody else once posted that they use a heated snomobile helmet. Sounds like a good idea to me.Good luck with your search-at least you've still got lots of time to look before the snow flies.(Hopefully)
   / meteor snowblowers on a Kubota #3
I have a 60" Meteor that has been on my B2410 for 5 years now and was used on my previous bota before that.
Paid around $1,300 new for it back in the mid 90s.
I added some new skid shoes but other than that and a new drive chain, it has performed well. Mine shoots 50 feet easily.
   / meteor snowblowers on a Kubota #4
I have a smaller one - 44" I think - on my BX.
I bought it new last year for $1000.
It blows snow just fine. I've only used it four time I think, and only two of those were "real" snows.
   / meteor snowblowers on a Kubota #5
I have a 60" Meteor with hydraulic rotation and hydraulic chute deflection on my B2410. It works well, but I have a fairly short drive and the distance I throw the snow is really irrelevant to me. I've never really understood why throwing snow 50' is better than 20'. As long as I get it out of driveway, how far it goes becomes irrelevant for my use. That said, I think the common wisdom is that closer fan tolerance equals further snow throwing. Closer tolerance and weight are also often associated with general build quality. There are other choices like the Pronovost and the Blizzard where I think you will find they have closer tolerance and more weight. However, for my use, the Meteor is more than adequate.
   / meteor snowblowers on a Kubota #6
When you need to keep a larger area open or throw the snow in your direction of travel, such as cleaning out an "L" shape, getting it a distance away means you don't have to run over it twice!!
   / meteor snowblowers on a Kubota #7
I've got a 68" Meteor for my L3400. I only got to use it a few times last year but it worked pretty well.
   / meteor snowblowers on a Kubota #8
i iv got a meteor snowblower 51 in on a bx1830 and it all hydraliq and it work grate
   / meteor snowblowers on a Kubota #9
I have a 5 footer on my 3030 and it throws the snow fine. I had a shear pin problem in the beginning but just beefed the pin up. I paid around 1300
   / meteor snowblowers on a Kubota #10
Is this a 3pth mount snow blower?
2014 FORD F150 4X4 CREW CAB PICKUP TRUCK (A52576)
2014 FORD F150 4X4...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
New/Unused 70in Quick Attach Seeder (A51573)
New/Unused 70in...
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
