MF 1030 2wd good tractors?
   / MF 1030 2wd good tractors? #1
mattman
ElDorado,AR
Kioti DK 35
I am looking at a used 1030 2wd with a little over 3000 hours, my questions are they good tractors? who made them some company in Japan I think? What do you think the life expectince is of a 93 model that looks to be taken care of except for needing some fresh paint. I am looking for a tractor to use in the woods for bushogging and to pull a small disk to plant some food plots. How satisfied are yall with the overall performance.
thanks Matt
   / MF 1030 2wd good tractors? #2
yes good tractors , ive got a 86 10-30 and its a good tractor
   / MF 1030 2wd good tractors? #3
I have a 1987 MF1030. It does a fantastic job on my 7 acre home site:thumbsup:
   / MF 1030 2wd good tractors? #4
I believe the 1030 was built by Hinomoto which is based in Japan. If it is like the 1010 it should have a Toyosha 3 cylinder diesel engine in it. I used to have a Simplicity 9518 (same as MF 1010) and was going to get it running but after spending over $600 on the injection pump plus numerous other parts I sold it and cut my losses. Parts shouldn't be too hard to get, yeah you will have trouble getting transmission parts but i am sure MF could get most any part for that model. 3000 hours is quite a bit for a small diesel, once they hit 2000 they get harder to cold start and you will start to replace parts every so often. Unless it is a super good price I would keep my eye out for a lower houred machine with 4wd, you will find 2wd to be very limiting. Just my :2cents:
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
Chery 6' 10 Drawer Workbench (A50121)
Chery 6' 10 Drawer...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A50323)
2000 Freightliner...
