Oil & Fuel MF 1098 ran out of Diesel Fuel- won't start
   / MF 1098 ran out of Diesel Fuel- won't start #1
awill99
Bronze Member
15 acres Celeste
Mahindra 6500 4WD with Skid Steer FEL.Mahindra 3616 HST with Skidsteer, Vermeer RT200 Trencher
Just bought a 1098 that had ran out of fuel. The diesel runs out of primary and seconday filters ok when I manually pump fuel pump but I can't get it to come out of low side or high side injector pump. Any thoughts on problem?
   / MF 1098 ran out of Diesel Fuel- won't start #2
Loosen the fuel lines at the injectors. Turn the key until you see fuel come out of the lines and retighten. DO NOT put your hands or eyes near the lines when doing this, the fuel spray could be under some pressure.
   / MF 1098 ran out of Diesel Fuel- won't start #3
Hi: If you pumped it up all you should have to do is to crack open the #one injector line, turn the Engine over until you see fuel come out, if you start to get fuel it should fire on its own ,if you don't get fuel at the line comeing out after a few turns then you will need to pump the fuel back up , keep trying to turn it over with the line cracked open DO NOT open more than one at a time you can do diferent ones but only one at a time, also you can loosen these lines at the back of the pump it will be easier than trying to get to the injectors, but if you can get to the line at the injector it would be much better . also rember you do not need to bleed all of them if the engine starts but it seems to run rough you can go to a difernt line and bleed it while the engine is running, this will tell you if you are on the right one when it smooths out
   / MF 1098 ran out of Diesel Fuel- won't start #4
it seems that there was A problem with my E-Mail Address so I fixed it and it should work now
2016 RAM 3500 HD SERVICE BODY TRUCK (A52576)
2016 RAM 3500 HD...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2022 Harley-Davidson FXLRS Motorcycle, VIN # 1HD1YWZ11NB021297 (A51572)
2022...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
