MF 135, 3 cylinder diesel, trying to turn engine over by hand
   / MF 135, 3 cylinder diesel, trying to turn engine over by hand #1
carholme
Ontario, Canada
Kioti CK 30
Gentlemen;
I have a 1970 British Massey 135 an I am in the process of removing the Injection Pump to repair some leaking seals. I need to turn the engine over by hand to get the flywheel and E mark in the pump aligned correctly. However, with the type of front axle I have, I cannot see a way to get a hand crank in there. Is there another plate somewhere that I can gain access to gearing to be able to rotate the engine??
Thanking you kindly in advance,
Gerry
   / MF 135, 3 cylinder diesel, trying to turn engine over by hand #2
U really don’t have to time it.
The drive hub has a master spline and the gear has a dowel pin that mates to it..
And on the mounting ear is a timing line.. that line mates up w either some degree marks or another line on the engine block..
Just go thru the front access plate (5 bolts) & remove the 3-1/2” bolts..
Do not move or disturb the gear after u remove the 3 bolts..
If you’ve never done it before, mark the gears to each other w a Sharpie..
Good luck.
Many thanks Sir, I will proceed and come back you you with my test run when re-installed.
Very kind of you to take the time.
Regards
Gerry
thepumpguysc and all;​
Everthing went extremely well, except on my first run after bleeding, couldn't shut the engine off. I am sure the experts will know what happened. Yes, the tit on the bottom of the shutoff shaft wasn't engaged with the sliding lever. Fixed that and all works a charm with no leaks.
Once again, thanks for the help.
Gerry
SCAN FOR HAULING AND FINANCING INFORMATION (A51247)
SCAN FOR HAULING...
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2020 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A53426)
2020 KENWORTH T680...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2015 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A53426)
2015 FREIGHTLINER...
UNUSED BB500 DUSTLESS BLASTER (A51248)
UNUSED BB500...
