MF 135 Multi-power filter
   / MF 135 Multi-power filter #1
namyessam
guess where
xyz
Changing the trans-diff fluid in my 135 and the multipower filter looks like it's covered with dirt. Is is possible or even feasible to remove the filter from the pump through the PTO cover or does the lift cover need to be removed? The filter is the bolted version. The bottom bolt is behind the pickup tube and seems like it would not be an easy job. Has it been done by anyone? I am considering using a tank type garden sprayer and using diesel in it to wash it down while in the case. There is some sludge in the bottom of the case that would benefit from the diesel also and I hope I can spray off the filter enough to avoid removing the top cover. Thanks for any advice in advance.
namyessam
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
