MF 135 year of manufacture is 1969 leaking coolant
   / MF 135 year of manufacture is 1969 leaking coolant #1
dexter195
coolant leaks from overflow tube beside the radiator cap.
the engine block is hot but the leaking coolant is cold.
when engine has stopped a gush of coolant is expelled from the overflow tube.
when the engine is ticking over and the radator cap is removed, air bubbles can be seen rising up through the coolant.
would this be caused by the thermostat being stuck in the closed position?
or would it be a faulty head gasket?
thank you in advance for your help
   / MF 135 year of manufacture is 1969 leaking coolant #2
could be a blown head gasket or even a cracked head i would also check and see if you have any antifreeze in the oil pan
   / MF 135 year of manufacture is 1969 leaking coolant #3
Dex, Hi and welcome to TBN...
You may actually have two problems ...1. The fact you have air bubbles in the radiator is not good , Looks like head gasket or crack as mentioned above.. 2. the cool coolant you mention could be due to a bad water pump or a blockage in the radiator or like you said a stuck thermosat that just not letting the coolant flow.. A test you could due to check flow is to run tractor until warm (10minutes or so) then feel upper and lower hoses , If bottom is hot and top is still cool its not passing coolant very well if at all. Do you have a radiator pressure tester? that could help you find a head gasket leak.
Keep us posted /forums/images/graemlins/cool.gif
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
2021 CATERPILLAR 279D3 SKID STEER (A52705)
2021 CATERPILLAR...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
