MF 1532 Stalling
   / MF 1532 Stalling #1
gary d
Amelia Courthouse, Virginia
My 1532 is stalling when the pto is engaged. When it was new I had a similar problem and it turned out to be the seat switch was not engaging due to the seat belt being under the seat and not allowing the switch to operate.
I am going along mowing and it starts to die and if I disengage the PTO real quick it will recover and keep running. I can then mow a little more and it does it again. I by-passed the seat switch to see if that was the problem but it wasn't. It runs and drives fine w/o the pto engaged.
Only 25 hrs on the tractor.
Any suggestions??
   / MF 1532 Stalling #2
I would check the fuel filter first but with that few hours that should not be the problem but you never know what you could get in the fuel these days. Also make sure that the fuel shut off is full open. Good luck and let us know what you find.
Jim
   / MF 1532 Stalling
I filled the gas tank and had no further problems. Must be a pick up problem w/ 1/4 tank of gas. I will have to see if the problem returns when low on fuel.
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
CATERPILLAR 320FL EXCAVATOR (A51242)
CATERPILLAR 320FL...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
2012 Ford F-250 Crew Cab Pickup Truck (A50323)
2012 Ford F-250...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
