MF 165 speeds by gear?
   / MF 165 speeds by gear? #1
greenfarmranchhome
texas
massey ferguson 165
I need to know what the speeds for a MF 165 without multipower is by the gear.
1 low - 1 high
2 low - 2 high
3 low - 3 high
4 low - 4 high
I know I could measure out 200 feet and drive the distance measuring with a stop watch and calculate it but I am in a pinch for time and thought maybe someone already had acces to these numbers.
Thanks everyone.
   / MF 165 speeds by gear? #2
If you have a GPS get on the road and see what it is. I have actually done that on mine to get a more exact speed when spreading chemical or other product that is more dependent on speed.
I wish I had one. I am seeding 5.5 acres of oats for a guy that wants 75 lbs per acre. I have the instruction sheet for what setting to set the spreader at for the certain speeds.
   / MF 165 speeds by gear? #4
Just started on tractorbynet and seen your post hope this helps.
Standard Clearance 14.9/13-28 tires
rpm 1500 2000
Low 1 .97 1.29
2 1.46 1.94
3 2.67 3.56
R 1.32 1.76
High 1 3.88 5.18
2 5.82 7.76
3 10.68 14.23
R 5.29 7.05
This info came from an owners manual for the MF 165.
Thanks. I actually slowed down for half a second and remembered the speed plate is still on the inside of the fender. Duh
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
2017 Freightliner Derrick Digger (A55973)
2017 Freightliner...
2007 50FT 3 CAR HAULER TRAILER (A58018)
2007 50FT 3 CAR...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
2012 Ford Expedition 4x4 SUV (A56859)
2012 Ford...
