MF-230 loose steering...
/ MF-230 loose steering... #1
ChronicCodez
Massey Ferguson
My MF-230 steering wheel is loose. The problem is in under the steering wheel. Underneath the wheel there is a circular plate with ten or so bolts where the power steering fluid is pumped. I've never worked on power steering so I don't know the exact cause of the problem.
What would be the culprit? If I remove the sealed plate would I have to bleed the steering fluid? And if that can be done easily enough would it be worth cracking open to take a look? And finally could this be repaired without buying new parts?
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63118)
2017 Yale GLC050VX...
Leeboy 8530 Paver (A61166)
Leeboy 8530 Paver...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
(2) 30 Yard Roll Off Dumpsters (A61165)
(2) 30 Yard Roll...
John Deere 1418 Bush Hog (A64047)
John Deere 1418...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2006 Ford F-150...
