Oil & Fuel MF 231 Hyd Oil Level
   / MF 231 Hyd Oil Level #1
nokia6650
Kopperl, Tx
Massy 231
sorry - probably been asked before - Tractor is working fine. The trans/hyd dipstick shows the proper level - between the M and A. BUt - when I open the plug by the shifting levers and look in the reservoir - it is empty?
Most reservoirs are a reserve to be drawn upon when needed. Should this one be filled to the top? Does it draw from the bottom of the reservoir in which case would a gallon be sufficient? The Operator and Maintenance manuals that I have do not answer these questions. They say to add 8.5 gal on a change out but no discussion on how much should be in in the reservoir. Some dealers say that if the dip stick level is ok then you are ok?
Again - if the level on the dip stick goes low how much shoud be in the reservoir to provide for proper operation.
Others have said that you need to keep the reservoir full to the top and the hole in the reservoir/tranny partitiion will take what it needs. Makes no sense as most of the volume would be wasted?????
Thanks in advance for any help
Tim Sullivan
MEGGER EZ THUMP (A50854)
MEGGER EZ THUMP...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
2024 Iron Bull 20' Equipment Trailer (A49461)
2024 Iron Bull 20'...
