MF 261 fuel leak
   / MF 261 fuel leak #1
markwmo
Central Missouri
Kioti DK40SE, MF 491, MF 261
I have a "98 MF 261 with the Perkins AD4.236 engine. I have a leak or drip at the top of the rear injector. I think it"s called the drip rail but it"s the pipe along the top of the four injectors. There is a bolt and steel washer on each side of the pipe fitting. The leak appears between the bottom of the fitting and the large nut at the top of the injector. I have replaced both washers but can"t get the leak to stop. Anyone have any thoughts or suggestions? Thanks!
   / MF 261 fuel leak #2
Check for a pin hole in the line, and be carefull that is high presure.
   / MF 261 fuel leak #3
Check for a crack near the banjo fitting, or a thin brazed spot. This is a low pressure return line.
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
JOHN DEERE Z960M LOT IDENTIFIER 93 (A53084)
JOHN DEERE Z960M...
2006 John Deere 317 Skid Steer (A52384)
2006 John Deere...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
1991 KALYN SIEBERT 60 TON LOWBOY TRAILER (A51247)
1991 KALYN SIEBERT...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
