Rpars
I recently lost all pressure in my front bucket and rear remotes. 3 point raises and lowers fine, steering is also good. After checking fluid levels and disconnecting, then reconnecting all of my lines to make sure everything had a good seal, I decided to check the pressure release valve on the lift pump. I removed the right side cover, slid my hand in to feel around a bit and grabbed a handful of parts sitting in the bottom (see attached). Looks like I'll have to split the tractor and pull the pump, but I've been trying to figure out what these parts are. I've looked on Agco and scanned exploded views of the hydraulic and implement drive systems. I guess I'm looking right past it because I'm not seeing a match anywhere. Anyone have any thoughts?
