MF 6180 pto/transmission/sensor problems
   / MF 6180 pto/transmission/sensor problems #1
Can Fixit
1997 6180 sheared off pto sensor tonite.Always leaked oil from pto flange,change large o-ring watched leak still appear.Put a magnet into bottom back of pto case and pulled up a 2.5 inch diameter steel casting plug that was hidden behind drawbar support frame. Oil leak was probably from that plug all this time,until it fell out into the transmission,or maybe sat on the bottom for a long time.Was going up a steep hill with pto on when it sheared the sensor.The plug got caught up in the gears of the pto inside then fell back to the bottom.Any one else has this problem?Got the plug out but some of the sensor,plastic part,not magnet,is in the bottom in the oil Thx
2014 Toro Workman HD Utility Cart (A51691)
2014 Toro Workman...
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
