mf gc2350 loader hydraulic problem
   / mf gc2350 loader hydraulic problem #1
john amsden
Folks,
Recently my loader joystick refuses to allow "down" in the usual manner. When the tractor is stopped and when it's first started up the "down" works fine. As it warms up it begins to refuse to allow me to push the joystick forward to drop the bucket. It will allow a very slight (slow) down if I push rather forcefully. In this situation I cannot push forward enough to allow the "float" position. I have notice a very small amount of leakage under the joystick mechanism. I have checked and filled the hydraulic fluid - no change. Anyone have any ideas?
   / mf gc2350 loader hydraulic problem #2
Remove the caps on the ends of the spools and see if any nuts or screws are loose, especially the nut on the end of the spool. You should also inspect and clean and fill with grease to help keep out water. Watch out for little ball bearings and springs. Keep a magnet close by.
International 133 6 Row Cultivator (A50514)
International 133...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
Quick Attach Pallet Forks (A47384)
Quick Attach...
Ih 490 Disk (A50514)
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
