bloody_peasant
My MF1010 overheats really easy when running the MMM. I have kept the radiator cleaned well and topped off, but it heats up real quick even when cutting fairly short/light grass to the point the temp light comes on and it starts spitting radiator fluid out. Probably takes less than 20 minutes for it to get this way.
At first I thought it was a factor of the hot weather, but now it keeps on doing it even though it was much cooler this past weekend. It actually seems to be getting worse
The fan is working as expected too.
Could this be a problem with the MMM, maybe not turning freely enough and causing the engine to overwork? Although the pulleys seem to move pretty freely. Could a dull blade cause it?
Could it be cheap coolant or the wrong kind? Could it be a problem with the water pump or the radiator?
What should be my first steps in trying to diagnose it?
Note, it doesn't seem to have this problem with the rear PTO and the bush hog.
Finally after it heats up like this, is there anything I should do like change the oil? I figure if the engine is getting that hot it could be causing my oil to prematurely break down or something.
Thanksl
Thanksl
