MF1250 FEL hydraulic pressure
   / MF1250 FEL hydraulic pressure #1
radioman
Super Member
Ontario, NY
Kubota BX24
Does anyone know how to check the pressure on MF1250 specifically? (tractor belong to my father and he doesnt use computers so I am doing this for him) I did a quick search here and did not find anyone doing it for the non-hst 1250 model. He is saying that the FEL feels pretty weak and I want to check it and add shims if needed. I am only familiar with my BX24 kubota but not MF. I finally got my agco account setup so I can use that for pics-
The only info I was able to collect from this TBN site is :
-max output 6.7 gallons/min
-relief setting is 2133 psi
-hydraulic strainer is on left side of rear axle
-3 pt can lift 1940lbs.
So here are my questions:
1. where is the spring and shim port so I can adjust PSI pressure? pictures?
2. where is best place on MF1250 to test pressure
3. is my facts gleaned from this site correct?
4. how much should the FEL be able to lift?
Bumping.need some answers.
Sent from my andriod using TractorByNet
More info coming soon! (A44572)
More info coming...
2007 INTERNATIONAL 4200 CAB & CHASSIS (A45676)
2007 INTERNATIONAL...
2010 UTILITY 53X102 DRY VAN TRAILER (A45677)
2010 UTILITY...
Forklift (A45336)
Forklift (A45336)
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A48561)
John Deere 5090E...
More info coming...
