Mf135 draft control lever stuck
   / Mf135 draft control lever stuck #1
Kiwitractor
Mf135 MF 165
MF135 draft control lever stuck,although I can move it just a touch.Hoping it may be in the control shaft externally,or do I need to look at internals?Lift controls work fine.
Any suggestions appreciated
   / Mf135 draft control lever stuck #2
Hi,
I've lifted the top cover off the hydraulics of a a similar tractor. From that experience I would say that this issue could be either the shaft that the lever rotates or the internal linkages attached. The internal linkages are a complex set up that control the hydraulic fluid flow to perform the position and draft control actions. They can break or wear and interfere with each other, causing a jam. I suspect that the hydraulic top cover will need lifting to inspect.
Get your hands on a MF135 manual, and beware, if I recall correctly, MF35's have a different utilisation of similar hydraulic control levers, suggesting that the internal linkages will be different, so don't use a 35 manual.
Thanks ,have freed it up with WD40 and problem was in the control shaft.
   / Mf135 draft control lever stuck #4
Phew, an easy fix.
Enjoy
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
2015 Chevrolet Equinox SUV (A50324)
2015 Chevrolet...
2019 CATERPILLAR 326FL EXCAVATOR (A51242)
2019 CATERPILLAR...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
