mf135 power steering pump issue
   / mf135 power steering pump issue #1
rednartso
Haven Ks
1033 massey
Have a early serial number mf135. The steering was very hard. Replaced the pump (round with upright reservoir) This works for a while then gets very hot and pushes oil out the seals on the gear under the steering column. Changed it out thinking the seals were weak, run tractor and still the same. Do not find a way to adjust pressure on the pump but seems to be way to hi as when you turn the wheel the hoses jump a bunch. Any Ideas?
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2014 Mack CXU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Mack CXU613...
Unused 2025 Electric Cart (A51694)
Unused 2025...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
