MF205 = Hinomotoe18 4wd engagement
   / MF205 = Hinomotoe18 4wd engagement #1
cansox12
Nevada County, NorCal
MF205= Hinomoto E184
4wd, 2cyl, MF205 or Hinomoto e-18: Runs good, shifts through all forward and reverse gears, (manual clutch-wet), pto operates in all gears, synchro mesh-posi loc at rear axle works. The 4wd engagement lever moves to the "in and out" positions. It feels like the lever is moving a syncro gear to the drive gear, but not grabbing the drive gear. Dosen't feel right, seems to me that there would be a fair amount of "thrust/tension/solidness" you would feel while moving the 4wd lever. (No, the front wheels do not rotate when raised off the ground.) I do have the correct IT repair manual but it is very vague and only isometric gear illustrations. Not enough for me to come to a dianosis.... Does anyone have a comment, link, post, thread, website, solution or have had the same problem...???
Spool of Wire (A47384)
Case-IH 165 Puma (A50120)
Case-IH 165 Puma...
John Deere 920 Platform (A50514)
John Deere 920...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A52748)
2019 Tico Yard...
John Deere 16 Row Cultivator (A50514)
John Deere 16 Row...
2003 Doyle Semi Horse Trailer (TITLE) (A50774)
2003 Doyle Semi...
