MF231 won't start
   / MF231 won't start #1
Butch4
MF231
Help,
Yesterday my MF 231 was running great, like always, and suddenly it appeared to run out of fuel. I confirmed the tank had diesel fuel. It is clean, no water in the fuel filter, and fuel is flowing. The motor will turn over but won't start. What is the next step?
Thanks,
Butch
   / MF231 won't start #2
Where have you checked for fuel flow?Do you have a mechanical shut off or an electrical solenoid shut off?
If you have continuous flow from the tank bottom through to the injector pump inlet, bleed the pump and the injectors.make sure the battery is fully charged and then make sure all the connections, bleed screws, etc are tight first( don't reef them down, just make sure they aren't loose). You might be suckinng air in somewhere. Make sure the tank vent (usually in the fuel cap) is unplugged. If you have good fuel flow to the fuel pump inlet and you can't get fuel at the injectors, I'd suspect the pump.
UNUSED HURRICANE MSC2020F ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2016 CHEVROLET 2500 TRUCK (A51247)
2016 CHEVROLET...
1268 (A50490)
1268 (A50490)
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
Electric Concrete Mixer (A51573)
Electric Concrete...
