MF30B Clutch Replacement
/ MF30B Clutch Replacement #1
Farris
MF30B
Hello all,
Farris here. First post so please bear with me...
I have a Massey Ferguson 30B loader tractor that needs a clutch. I've started splitting the tractor and my question is; can the loader be left on the tractor then split and roll the rear section back or will the loader have to come off? The tractor has a three point lift and PTO. No back hoe or roof. Also, will the entire dash/steering assembly have to be removed or can I leave the dash installed? Thanks in advance guys!
-farris
/ MF30B Clutch Replacement #2
If you have the 6x6 shuttle, or 8x2 transmission and a 32a or 34a loader you will most likely want to leave the loader attached to the front and roll it back from the rear. If you have a different loader it will most likely be easier to remove the loader. The dash can be left on the rear of the tractor, you will have to disconnect the steering lines and electrical. When rolling the rear back make sure the transmission is in neutral. If you have any questions let me know. I have a 20C, that is almost identical to the 30B (except the rear axle).
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
2021 Frontier GM4060E Mower (A64047)
2021 Frontier...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
2017 Bad Boy Outlaw XP 61in. Zero Turn Commercial Mower (A61567)
2017 Bad Boy...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
2001 John Deere 6210 (A60462)
2001 John Deere...
