mf35 gas tank
   / mf35 gas tank #1
griptongue
Idalia colorado
yanmar 226d, mf35
my mf35 gas tank started leaking. cheapest I've found is $290 delivered ! anybody know where reasonable priced tank is ? If not I quess I will try to epoxy it.
   / mf35 gas tank #2
Dealer??
Try A & I
Sparex
Bareco
Walts tractor Parts..
   / mf35 gas tank #5
Is the tank metal or plastic? There are several multi-part sealers that work very well on motorcycle tanks and I have seen them used on garden tractor tanks. There are different formulas for plastic and metal tanks as I remember and the metal tank one uses a etch step to remove corrosion from the tank. Some of the Wheel Horse tractors I collect have a cast aluminum 2 piece tanks where the flat bottom is bolted to the casting. There is a gasket but every one of them will leak unless you put the sealant in the tank.
One sealant is called Kreem, it is not cheap but here is a link:
Kreem Fuel Tank Liner - Street Bike - Accessories - Motorcycle Superstore
I have heard people swear by Red-Kote for metal tanks you can get it at O'Reilly Auto parts. More info about Red-Kote is here:
Damon Industries :: Chemical Cleaner Cleaning Custodian Custodial Degreaser Degreasing Deodorant Disinfectant Disinfecting Floor Finish Housekeeping Jan-San Janitor Janitorial Sanitizer Sanitizing Sealer Treatment Wax
Bruce
Bruce
2007 and Up Dually Bed for Ford (A44391)
2007 and Up Dually...
Case IH 455 Round Baler (A46877)
Case IH 455 Round...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A43004)
2018 PETERBILT 579...
2010 International 4300 U3-HK Hooklift Truck (A44571)
2010 International...
2012 Freightliner Cascadia 125 Truck, VIN # 1FUJGLDR2CSBU1926 (A44391)
2012 Freightliner...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A44572)
2018 Toro...
