MFWD?
   / MFWD? #1
Frosty
Bronze Member
SW Idaho
Kioti CK35 HST; Kubota KX040
What does MFWD mean? I see it a lot in ads for large farm tractors. I figure the "FWD" means four wheel drive but I sure can't figure the "M". /w3tcompact/icons/hmm.gif
   / MFWD? #2
Mechanical Front Wheel Drive
   / MFWD? #3
The "M" was to distinguish mechanical front wheel drive (transmission driven) from hydrostatic front wheel drive (HFWD) which was hydrostatically driven.
   / MFWD?
Thanks fellas -
I don't think I've seen HFWD. Is this newer than the MFWD? Is HFWD typically preferred for most field operations?
   / MFWD? #5
At one time Deere had Hydraulic Front Wheel Assist as they called it,but not for long. Once they saw that everyone else had a better mechanical system they finally switched over. The hydraulic systems are only for limited use to help you through a sticky spot,not continuous use like true mfd systems.Hydraulic systems do not lend themselves to loader work either very well!! I guess that is why we do not see them on tractors today. Some owners of 20,30,and 40 series Deeres with HFWA say all, they do is smoke and scream when they engage the front axle,and go no where.
   / MFWD? #6
the fortake of a HFWD is that it is cheaper, cause there are only Oilpumps in the frontwheels, that block them. But when they are overloaded, perhaps in the mud, they switch off, and You stick in the s...!
Bernhard Derichsweiler, Germany
   / MFWD? #7
I can't speak for the tractors, but apparently the HFWD on Deere graders is a real nice system. I guess they made some improvements since it was on the tractors.
JT
   / MFWD? #8
There are many full time hydraulic only drives on heavy equipment. I'm not just talking about straight automatic trannies either.
Our big milling machines, and some rollers have indepentent hyd. motors on each wheel.
They work until they fail is about All I'll say about them... they have their pro's and cons... less drive train, but more maintenance. etc,
Soundguy
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
