Mig welding machine
   / Mig welding machine #1
roadrash
Ponchatoula, La
Kubota L3010
After several years of debating with myself, I finally bought a Mig machine. I looked at my stick welding and thought their has to be a better way. My problem was that by the time I could start running a good bead, the job was finished. Thanks to grinders I could make do, but was not satisfied with the weld quality. Went to a local welding supply co. yesterday an bought a Millermatic 175 and a cylinder of mixed gas. I am now a happy camper!!! Played with the settings some and ran some pretty beads right off the bat. Joined some flat plate and used the "big hammer" test for penetration!! /forums/images/graemlins/laugh.gif Kicked myself for waiting so long to get a machine. Oh' picked up a auto darkening sheild at the same time, I am now out of the dark ages!!! All I can say is get one, you will like it!! /forums/images/graemlins/smile.gif
   / Mig welding machine #2
I have had a Millermatic 175 for almost 4 years now. Once you figure out the settings for the different types of steel you will be in welding heaven. I have found that I can weld up to 1/4" plate in one pass and sometines up to 3/8" depending on circumstances. Anything thicker requires multiple passes.
Good luck and keep practicing with scrap.
   / Mig welding machine #3
I have the "poor sister" to your Millermatics but am pretty happy with my Hobart Handler 175. Road, you did a wonderful thing for yourself getting the auto darkening helmet. I've had mine since day one and couldn't imagine being without it. /forums/images/graemlins/cool.gif
   / Mig welding machine #4
I've got the "poor little sister" of the MM175 (Hobart Handler 135) and I couldn't be happier. I would have prefered the 175, but I needed to be able to plug in anywhere and the 135 was the best I could do with that requirement.
   / Mig welding machine #5
Picked up a MM175 late last Fall, and the kids got me an auto-darkening helmet for Christmas. I share your enthusiasm for this setup. That reminds me. The C25 is way low and needs a refill. 80CF goes a long way though....................chim
   / Mig welding machine #6
I'm still deciding whether I can justify a welder. Do you notice you have to do a lot of cleaning up before using the MIG? I used a rented stick welder to fix my brush hog, and didn't do any prep work at all on the dirty, painted metal.
   / Mig welding machine #7
Alan L.
A stick welder and 6011 rods are a "burn thru almost anything" combination. Not the cleanest or prettiest welds but workable without alot of prep work.
Mig welders are great in a shop environment, but for me they never seem to perform well outside in the breeze (or wind... it always seems to kick up when I want to Mig outside!).
I have a flux-core Mig that is great for thin stuff and just recently bought a Hobart Champion 4500, engine-driven AC stick welder/generator combo. The Hobart can go anywhere and weld most anything (except aluminum), and also provide power for my little flu-core, making it portable as well.
I like Migs, they just don't fit my heavy welding needs as well as a stick machine!
BTW,
I live in about 15 miles west of Sherman... what part of the county are you in?
   / Mig welding machine #8
Like Zoomie said, the MIG's depend much more on a breeze free environment, clean materials and a good ground to operate well. Ugliest welds I've seen are MIG when some smart aleck has cut off your gas ! Now, if I can ever get used to the self-darkening helmets - guess you can call me old-school.
   / Mig welding machine #9
<font color="blue"> Like Zoomie said, the MIG's depend much more on a breeze free environment, </font>
This assumes you're not using flux core wire, right?
   / Mig welding machine #10
</font><font color="blue" class="small">( Do you notice you have to do a lot of cleaning up before using the MIG? I used a rented stick welder to fix my brush hog, and didn't do any prep work at all on the dirty, painted metal.)</font>
Mig works best when both surfaces are prepped clean. However, unlike stick welding, there is no slag to remove when finished. You either pay the labor price before welding or after welding, making this mig vs stick issue moot.
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
71050 (A49346)
71050 (A49346)
Informational Lot - Financing (A51039)
Informational Lot...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
2020 MACK PINNACLE (A50854)
2020 MACK PINNACLE...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
