Minimum Angle to Dump Dirt
   / Minimum Angle to Dump Dirt #1
ctpres
BAR BOB Ranch, Needville Texas
Kubota 3400HST
Looking for cheep dump trailer for my pond project. CMI six foot one ton with factory hand pump dump kit, less wood delivered is $682. With a dump angle of 40 degrees I have no idea what to expect.
   / Minimum Angle to Dump Dirt #2
For dumping dirt you will need 45 degrees plus. Loose material will dump at 40 degrees but not consistently. A true dump truck dumps at an angle of 60 degrees and even then they use a vibrator to expel sticking material. This has always been a gripe of mine for "dump trailers". Try looking for a used hydraulic dump trailer w/a deep cycle 12V battery for power.
   / Minimum Angle to Dump Dirt #3
If your pond involves dumping clay you need LOTS of angle. You will get tired of a hand pump REAL quick. Sorry....
   / Minimum Angle to Dump Dirt #4
My dump trailer goes to a 50 degree angle. It will still hold some wet dirt on the edges.
   / Minimum Angle to Dump Dirt #5
.... You will get tired of a hand pump REAL quick. Sorry....
Best to spend the extra dollars for a 12V power hydraulic operated dump trailer. It'll pay for it's self in the long run and once you've finished the pond, you could sell it for almost what you've paid.
   / Minimum Angle to Dump Dirt #6
If you go with the hand pump, have your do-it-yourself heart surgery kit handy, because you're likely to have a heart attack. I'd try to rent a dump trailer. I find the amount I use mine doesn't justify the cost. You need a pretty steep angle to get dirt out, gravel and mulch are easier.
2016 Yamaha Wolverine UTV (A47369)
2016 Yamaha...
2012 Vermeer BC1000XL Towable Brush Chipper (A46683)
2012 Vermeer...
24in Tractor Backhoe Bucket BT4555 (A48561)
24in Tractor...
Lockwood 36” Screen Sizer (A47369)
Lockwood 36”...
3108 (A46502)
3108 (A46502)
7ft. Model 1287 Brush Hog (A46502)
7ft. Model 1287...
