Minimum PTO HP for haying and associated implements
   / Minimum PTO HP for haying and associated implements #1
Hayseed Andy
Lake County, Florida
JD Z915B ZTR
Hello, all. Giving some thought to doing hay work (as well as other chores) around some acreage I have acquired. It is 5 acres, with the possibility of 5 more. What would I need as far as a tractor and implements to do the job properly and without being underpowered? I lean towards Kubota, with John Deere as a runner up. At some point, I could see it becoming a side-gig to help pay bills. Thanks.
   / Minimum PTO HP for haying and associated implements #2
WELCOME TO TRACTORBYNET.
I do not hay myself, but hay is raised around me.
Haying requires multiple expensive implements.
I speculate it takes sixty (60) acres to break even raising hay on a hobby basis, assuming two harvests per year, in Florida.
Equipment is available:
VIDEO: Tractor Tools Direct - Haymaking Packages for Compact Tractors - YouTube
IBEX TX HOBBY HAY PACKAGE DEMONSTRATION VIDEO - YouTube
Good luck to you.
Giving thought to a tractor for five acres I have acquired, with the possibility of 5 more. What would I need in a tractor?
LINKS (2): tractor for five acres site:tractorbynet.com - Google Search
tractor for ten acres site:tractorbynet.com - Google Search
VIDEO: Kubota BX Series VS. B Series - YouTube
There are several well developed threads in the T-B-N archive on the cost of operating a compact tractor. Owners that keep meticulous records calculate the full cost of operating a compact tractor WITHOUT IMPLEMENTS, with the owner performing routine service but purchasing OEM parts and fluids at circa $25 per engine hour. I concur.
(Subcompact/compact tractor =1,700 pounds to 4,500 pounds bare tractor weight)
I have numerous implements. I fuel and grease my tractor, the Kubota dealer or the welding shop perform all other maintenance and repairs, including transportation. I calculate my operating cost at $35 per engine hour.
   / Minimum PTO HP for haying and associated implements #3
Squares are more labor intensive but can be very profitable . If your handy with a wrench you can get older equipment very cheap. Cutter rake and baler for around 5 or k . most all of this type equipment can be handled with a 40hp tractor. The coop can fertilize for you or rent you a buggy. 4 or 5 cuttings can be done if weather cooperates just a little . 5 Acres is easy to get done in 3 days. Its better to cut every 28 to 30 days . your yield will be lower each cutting but quality will be higher and if you can squeeze in 4 or 5 cuts the qty will be the same as the guy that only cuts 2 times and you will double the TDN and protein of that guy. Make the kind of hay you would feed to your animals and you will not have any problem finding customers. I bale hay for personal use and sell the excess. I have had to turn down 3 people this past week needing hay because I have already committed what I have to customers . Word of mouth gets around pretty quick if you make good product. I do a 700# round and 90% of what i sell is 1 roll at a time to folks that have a few horses. Its hard work but I look forward to hay season like most people look to go on vacation.
Thank you both for the input and links. I have been watching a lot of YouTube videos to try and get an idea of what to look for. I find this line of work fascinating. I can see it as a side gig, and then eventually something to do during retirement.
M5farms, what does TDN stand for?
   / Minimum PTO HP for haying and associated implements #5
Total Digestive Nutrients
Understanding a hay analysis puts you in the driver seat when dealing with hay customers that think looks and color are the determining factor when buying hay. Knowing the TDN and protein content a person can determine what supplementing needs will be according to the animals they are feeding.
   / Minimum PTO HP for haying and associated implements #6
M5farms how many acres do you hay?
   / Minimum PTO HP for haying and associated implements #7
Andy I only have experience in TX, but I will say there are a number of folks interested in small hay operations on this forum. Here are my thoughts. For 5-10 acres you will likely never see a return on your investment (ok maybe in 40 years). So if you are doing this for profit, my advice is dont. However, if you have money to burn then go for it. I suppose haying can be a hobby if you wish. It is certainly rewarding to have many excited and thankful customers if you produce a quality hay product. In East Texas there are many that bale weeds and still sell them. Don’t be that person!
For tractor size, it really depends on what type of bales. If small squares only, you can get buy with a smaller machine. If you want to go large round then you need big machines. For your property size I would go square, but perhaps talk to others in the area to see what they suggest. Once you decide this we can talk specifics about machines.
   / Minimum PTO HP for haying and associated implements #8
I cut and bale 105 acres 3 to 5 times a year. 20 acres is Tifton 85 Bermuda (going to plant another 12 acres this spring ) It can be cut every 30 days when the weather is cooperates. This is what I feed along with some bahia and crabgrass hay.
   / Minimum PTO HP for haying and associated implements #9
If you're interested in baling with a two-twine small square baler, you can run one of these with a small CUT with about 20-25 hp (pto). Here's a video showing a Farmall Super A baling on a level hayfield with no problem. The baling portion of the video starts at the 5 minute 45 second mark. The Super A has about 16 hp (pto).
FARMALL Super A - YouTube
Good luck
   / Minimum PTO HP for haying and associated implements #10
Keep in mind, while a CUT tractor may pull and operate a baler efficiently, what control of the tractor do you have when you also hook a wagon behind the baler? Unless you elect to discharge the bales on the ground and manually load them on a wagon. It will be like the tail wagging the dog. Compound the situation if baling on a hillside. Weight and traction of the tractor play a key roll in a safe operation.
2025 KJ K1428 UNUSED (60) 28 in. High Traffic Cone (A47484)
2025 KJ K1428...
2016 Yamaha Wolverine UTV (A47369)
2016 Yamaha...
2025 Wolverine LHR-TWP80 Semi-Trash Water Pump (A47484)
2025 Wolverine...
2025 BisonTek BT360 UNUSED Riding Skid Steer (A47484)
2025 BisonTek...
2025 AllMetal K2010 UNUSED Portable Chicken Coop (A47484)
2025 AllMetal...
More info coming soon! (A44572)
More info coming...
