Minor problem.Major headache.
   / Minor problem.Major headache. #1
Topkicker
Platinum Member
Eolia, MO
Kubota L2501
Had my first quality issue with my new Massey 1529. I lifted the hood to jump off my lawn tractor that hasn't been used in a while. As I leaned in to hook up the jumper cables the hood fell on my head. I first thought the hood arm did not catch properly. After raising the hood off my head, I saw the arm swinging freely from the hood. The bolt had vibrated out and decided to fall on my head at the very moment I leaned in. The bolt was laying beside the valve cover so I lined up the prop arm, put the bolt in, and released the hood with my now very tired left arm. I was in a hurry to turn the tractor off so the bolt wouldn't vibrate out again. I made it to the key and turned the tractor off. Then found a nut in my tool box to put back on the bolt. It was a simple fix but I got a raised knot on my head in the process. By the time I got the lawn tractor cranked, I felt like someone had poured a 55 gallon drum of a**whoop on me.:mad:
   / Minor problem.Major headache. #2
Wow! Glad you were not seriously hurt. Head injuries can be very serious. Anyway, It might be a good idea to replace that nut with a nylon insert lock nut to prevent any further vibration issue.
   / Minor problem.Major headache. #3
They did. It sucks when an inanimate object kicks your a**!:laughing:
I moved and restacked 18,000 lbs of hay on Saturday. Used the strings to move it. It was noon today before I could close my right hand into a decient fist again.:(
LEEBOY 8520 APHALT PAVER (A51242)
LEEBOY 8520 APHALT...
AGT drum mulcher SSFM81 Attachment (A50322)
AGT drum mulcher...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
Toro Z Master Mower (A50322)
Toro Z Master...
2014 New Holland T8.360 MFWD Tractor (A52128)
2014 New Holland...
