mitsubishi 370 deisel no pressure from fuel injector pump
   / mitsubishi 370 deisel no pressure from fuel injector pump #1
marc1959
started with black smoke almost suet replaced all lines and filter bled air out to the pump then nothing from the pump tried to check pump gasket cant remove pump
   / mitsubishi 370 deisel no pressure from fuel injector pump #2
check and see if side plate is there if so remove and make sure the spring pistons are going up and down also theres a dip stick on back see if there is any fluid if not it may need to be primed like pump. check filter and make sure fuel is coming from tank.
2021 Allmand Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
2006 Magnum 125 125kW T/A Towable Diesel Generator (A53421)
2006 Magnum 125...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
