Mitsubishi 372 battery size
   / Mitsubishi 372 battery size #1
AlabamaNorm
Mitsubishi 372
I need a new battery for a Mitsubishi 372...anybody know which one I need ?
   / Mitsubishi 372 battery size #2
Can just measure the battery space to find one the correct physical size, then just get the one that size with the highest cca
   / Mitsubishi 372 battery size #5
Greg - I have the original batteries (dry charged) in stock or you can go to the local auto parts store and by a 22NF battery. It is a little taller than the original but works very well. Use a heavy rubber tie down strap instead of the battery holddown. We have parts and service for your tractor here in Roanoke. Call 1-800-609-5110. Bill
Thanks much- that's just what I needed. The old battery was marked 322NF which I couldn't find listed anywhere. I found a 22NF at the local TSC. I will keep your number should I need any Mitsubishi parts!
Is a front plastic grill available?
Thanks,
Greg
   / Mitsubishi 372 battery size #7
Well,
you’d need to pop the hood first….😬
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
2014 Bobcat 15C Skidloader PHD (A50774)
2014 Bobcat 15C...
John Deere 2210 Compact Tractor (RUNS) (A50774)
John Deere 2210...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
