Lebby
First time for posting new thread. Please bear with me. OK?
Just recently took delivery on a Satoh Bison. Has a few problems here and there but getting most of them straightened out. I hope anyway. My current dilemma has to do with the wireing. Somebody in the past rode this Buffalo hard and put him away wet.
Prior to me purchasing this tractor, the previous owner? did some major cooking of the wire harness. Wire colors for the most of it are still recognizable. The original Mitsubishi altenator has been replaced with a Delco which I believe is a 10SI. (Brief description: Says Delco - has one "Bat" terminal - has one "Grd" terminal - has a rectangular port with two plug in wires. Port on my left is stamped with a "R" and has a yellow wire coming from it. The port on my right is stamped with something that resembles possibly a small star. It could be some letter but I realy cant tell for sure. There is a green wire coming from this port.
Ok I'll take a breath here...
Attached to the side of the altenator is what I beleive is the new regulator. (Brief description: Stamped tin filled with an epoxy of some sort. Is approx. 1 3/8"wide x1 7/8" long x 1/2" thick. Under neath is a tag that states: Transpo - D7014 /12 volt- 241 The yellow and green wires come out of this and are plugged into the altenator. Also a black wire that attaches to the "Grd" terminal on the altenator. A faded red wire that is attached to the "Bat" terminal on the altenator. Last but not least there is a stubby orange wire protruding from the epoxy that has been capped off.
More useless information to consider....
Tractor charges well (14.5 volts), lights are bright and keeps the battery fully charged.
Have preceeded to check out all of the wireing per Satoh S650G wireing diagram. While doing the traceing of the wires I discovered that:
1. The old mitsubishi voltage regulator was still somewhat hooked into the sytem. The six attached wires under the Mitsi regulator had fried most of the insulation off. There was a small amount left so I could identify the color code. Four wires were cut off just short of the altenator. These were taped off and tucked into the wiring harness. These were the wires for the E-N-F-A tabs on the old altenator. I would guess don't need them with the new setup. The larger black-white wire which fed from "Bat" terminal on old altenator to "B" post on starter switch was also cut off and retaped. It had a major melt down. This is still hot probably not hurting anything.
2. The yellow-green wire runs thru/to the "L" tab of the volt. reg. this I believe is for charging lamp. I beleive this is still working properly. The black wire feeds in to the "IG" tab on the Mitsi regulator. This is fed by voltage that comes from the "IG" terminal on the starter switch.
3. Voltage for the system comes from "Bat" terminal on altenator and feeds into large (+) terminal on the starter.
Almost done here...
I would like to get rid of all the extra, melted wire and old Mitsi regulator as possible and replace with a newer wiring harness.
Last question/s here:
I would like to eliminate the old regulator. If I do this I will have two wires left over and not sure how to incorparate them into the new system or if I need them. These would be the wires before mentioned in #2.
Once again thank you for your patience and thank you in advance
LEBBY
Almost done here...
LEBBY
