Mitsubishi d 1500 engine
   / Mitsubishi d 1500 engine #1
gamefarm1
Need help in identifying the engine in my d 1500 2 cylinder diesel tractor.
The only markings on the engine I can find are
"1 5 PS, with the #'s 0.854 stamped on the right side.
Under that on the block are the #'s 80 8 stamped.
Need to find rod bearings for it, and crank specs, but can't until I ID exactly which engine I have.
Thanks, Truman Dodson
   / Mitsubishi d 1500 engine #2
The information I have shows it is a KE 85 engine with 764 CC. If it is a D1500FD, it would be a KE75 with 854 CC. My 3 cylinder tractors have the CC number cast on the side of the injection pump. I found this info on the Mitsubishi club site on Yahoo. If you go there, click on the files link then Ed Krampitz data.
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
LINDE WELDER (A53843)
2006 Ford F-350 Forestry Dump Truck (A51692)
2006 Ford F-350...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
