Mitsubishi MT160D
   / Mitsubishi MT160D #1
nikko4
Portland Oregon
Mitsubishi MT1601D
I have just replaced alternator, battery and field coil but battery will not charge and I cannot measure any drain. Is there a fuse in line that does not show on schematics?
   / Mitsubishi MT160D #2
Just looked in my manual (I own a MT180D).
Don't see any additional fuses other than the fuse box.
Recently I also had some electrical 'gremlins' and discovered that some fuses were making bad contact.
I resoldered the leads going into the clips that hold the fuses in place and that cured my intermittants.
In my case my battery was flat dead after using the tractor for about 2-3 hrs as I was getting all drain and no charge.
You state 'field coil'? do you mean the regulator (PN RQB2220D1)
You know at the current age of these tractors we have to be on the lookout for corrosion induced electrical problems, especially in humid climates.
I, for one, have had over the last year or so, probably wire brush cleaned just about every contact and bonding (ground points) in an attempt to maintain my Mit up to snuff.
A dielectric greese on exposed contacts will help eliminate lots of problems.
(Even vasoline is better than nothing)
Good luck!
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
434669 (A48836)
434669 (A48836)
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
SET OF (4) BRAND NEW CHAINS AND BINDERS (A53843)
SET OF (4) BRAND...
23169 (A50324)
23169 (A50324)
2019 Chevrolet Express (A50123)
2019 Chevrolet...
