Mitsubishi MT372 Mule Pulley Belt Tension Adjustment
   / Mitsubishi MT372 Mule Pulley Belt Tension Adjustment #1
goinnorthsoon
Litchfield, Maine
1984 Mitsubishi MT372
I have a 1984 Mitsubishi MT372 and I have just replaced the mule pulley drive belt. When it is engaged, the pulley guards get really hot after just a few minutes of use. I noticed the bar was out of the adjustment area (in between the arrows where it is stamped run). I made an adjustment on the threaded rod attached to the engage lever. I'm right at the end of the threads and the bar is about on the top arrow now, when engaged. Any ideas? Belt too short? The new belt is 109" and the old measured 109.5". Any help would be appreciated. Thanks.
Eric
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
2015 Kubota KX71-3S Mini Excavator (A52377)
2015 Kubota...
