Coachnic
Last year I noticed a leaking coming from around the screw that holds the fuel bowl and filter in place on the Fuel Assembly unit. I pulled it off and saw that the ORing was not in the best of shape so I ordered a new one and replaced it. Still, I noticed after running the tractor for an hour or so, it was still leaking from around the O Ring running down the fuel bowl. I then replaced the whole fuel assembly, bowl and O Ring and now it's still leaking from around the bowl after running it for a while.
Is there anyone else having this problem with the 2050FD's and if so, what have you done to repair it.
Lastly, I am in need to replace a small hose that connects from the bottom of the radiator and runs to the petcoack drain plug. Is this just a simple hose I can pick up at a local parts dealer or do I have to special order it?
