mix 30 weight oil with hydraulic oil
   / mix 30 weight oil with hydraulic oil #1
jcskippy
houston,tx
long
what should I do. Its a long tractor I've drain the hydraulic tank, replace with hydraulic oil, but it seem i have no hydraulic pressure to lift the bucket. Should I bleed all the hydraulic lines and the drain the hydraulic tank again?
   / mix 30 weight oil with hydraulic oil #2
You need to find out if the pump is pumping.
Might have lost prime.
TMA (A49461)
TMA (A49461)
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2016 Chevrolet Sonic LS Hatchback (A53424)
2016 Chevrolet...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53473)
2016 Ford F550 4x4...
