MMM binding on HST
   / MMM binding on HST #1
Bota76er
Okaloosa CO, FL
Kubota B7610
I've noticed under certain conditions (on a slope with 3PH w/BB all the way up) the reverse HST pedal on my B7610 will hit and limit travel or bind to the point of sticking against one of the MMM linkage pins. It's the 24B model 54" MMM in the up and pinned position. If I lower the BB about half way it seems to eliminate the interference. Anyone else had this one? Any suggestions?
   / MMM binding on HST #3
Before you shorten the offending pin as in that other thread, try removing it and inserting it from the opposite direction. This puts the head of the pin, rather than the end with the cotter pin, on the side where it's binding and that end is shorter. It's tough to get in there but you only have to do it once. I had the same problem with my B7500 and this totally eliminated the problem.
Jeff
Jeff,
Thanks for the suggestion. I turned the pin around. It was a pain to get the cotter pin back in but with two pairs of needle nose pliers and some patience I got it back in. Haven't had a problem since (with the MMM anyway, my computer on the other hand got thrashed by a virus which is why it took me so long to reply /forums/images/graemlins/frown.gif)
   / MMM binding on HST #5
You're welcome, glad I could help. /forums/images/graemlins/smile.gif
Jeff
1992 Kenworth T800 Semi (A50514)
1992 Kenworth T800...
71065 (A49346)
71065 (A49346)
Case 580D (A47384)
Case 580D (A47384)
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
2004 JOHN DEERE 5320 TRACTOR (A51243)
2004 JOHN DEERE...
E-Z Trail 680 Head Cart (A50514)
E-Z Trail 680 Head...
