rifflerunner
All last summer I struggled getting the MMM installed simple because the rear links will not lower all the way down on their own without alot of help (a heavy duty digging bar used to pry them down). After the mower is installed, the rear links go down all the way probably because of the added weight of the mower. And yes, I do set the cutting height control to zero before attempting to lower the links. I still have a good month or so before I have to worry about grass cutting, but has anyone else experienced this same problem? Do those rear links just get some slight rust buildup that prevents them from lowering down without any weight attached? Sure would be nice to have those links go down on their own the entire way to make this a quick job this summer. Thanks for any help.
