Anonymous Poster
Epic Contributor
- Joined
- Sep 27, 2005
- Messages
- 29,678
I'm looking for some advice to help with an adjustment problem on my belly mower. Its a 6' unit mounted on a model 1070 4wd with turf tires. The machine is a recent purchase so I'm still learning. When I purchased the machine, I noticed both the front and rear tires were reversed, valve stems in, which is good because it gives me a wider footprint when I'm using the FEL. The problem with the mower is this. In a hard right or left turn the front wheels will rub the front edge of the mower deck. From what I can see, and with information gleaned from the manual, there is an adjustment on the lift links that run from the rear of the deck to the lift brackets on the 3 ph. Before wrenching on parts and/or changing wheel positions I'm curious to know if anyone else has experienced this problem and what suggestions you guys might have.
