Ballast modifying wheel weights to fit
   / modifying wheel weights to fit #1
bdog
Elite Member
Texas
John Deere 6130M
I just called my dealer and wheel weights for my tractor are $375 for two 200lb weights.
I have two 200 lb wheel weights laying around that were for my old tractor. They fit up against the wheel fine but the bolt holes don't line up. There are four bolt holes on the weights.
I was thinking of centering them on the wheel as best I can and drilling 4 holes to mount them. I think it will work fine but I guess I am just a bit leary of drilling in the wheels. Any reason not to do this?
   / modifying wheel weights to fit #2
Make you a plate with both sets of bolt holes. Then you won't have to worry as much as stress cracks.
   / modifying wheel weights to fit #3
You could also make an adapter bracket, that had 2 sets of holes.. on for the weight,.. and one for the rim.. a few lag bolts later and you'd be good.
Soundguy
   / modifying wheel weights to fit #4
bdog,
I wouldn't drill the wheels. Making an adapter of some sort sounds like a much more reasonable idea.
2006 DITCH WITCH RT40 RIDE ON TRENCHER (A51242)
2006 DITCH WITCH...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2016 FREIGHTLINER...
2006 Chevy Trailblazer (A47384)
2006 Chevy...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2014 ORTEQ ENERGY SERVICES MANIFOLD TRAILER (A50854)
2014 ORTEQ ENERGY...
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
