Montana 4540 starts but won't move
   / Montana 4540 starts but won't move #1
minihorsefarm
maine
Montana 4540
My tractor starts right up but won't move. Any suggestions? Last time I used it everything was working fine with no issues.
   / Montana 4540 starts but won't move #2
What kind of transmission do you have? I ran into that Saturday on mine (2740), but it had popped out of gear (shuttle shift and my legs are long). I panicked at 1st because I have only owned it for a month or so.
I have the 12 speed shuttle transmission. The shift levers seem to be working properly, they aren't bond up or sloppy feeling. I was wondering if it was a bad switch.
Thanks.
   / Montana 4540 starts but won't move #6
I have a 5740C Montana it has 16 forward and 16 Reverse. The way u explain the problem, I feel the problem is either a result of shifting linkage, or the low or high range is not selected.
The problem could as well be the FORWARD & REVERSE lever needs a little suppleness when asking it to go F or R. I would also use lube oil on the linkage. If these ideas do not solve the the problem. Then I would look into the more costly fixes. They would be either the clutch or the forks in the transmission that select the gear is not functional. Their is a fork for each lever which is used to select any of the 16 forward or reverse as well as low or high ranges. This happens to me once and awhile and its just that I have not selected a gear properly and it is jambed or just in neutral. Hopefully its the cheap fix and not the tranny or the clutch. Good luck!
   / Montana 4540 starts but won't move #7
Super old thread sorry...but having the same issue on my 5784 with no resolution so far
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2015 FORD F-450 SERVICE TRUCK (A52472)
2015 FORD F-450...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
