Montana 4944
   / Montana 4944 #1
Capt Windmill
Athol Id
Montana 4944 - Ford 8n
This is my first time using my tractor with a 6 foot field mower. I have gone through 4 shear pins in one afternoon. As I let the clutch out to engage the pto I hear a bang and shortly there after the pin is broke. Could someone tell me what speed and gear to use to rectify this problem. Yea I'm a rookie.
Thanks.
Rob
   / Montana 4944 #2
Thanks.
Rob
make sure you are starting the pto at low rpm. If you start it at to high rpm you put much stress on your pto and other parts and that leads them to break. Once you get it going at lower rpm you should run the brush hog at whatever rpm you get 540pto speed. I usually run my slightly lower around 2100-2200rpm. As for gear use what ever you feel safe. You can go faster in shorter grass slower in tall grass. Just pick a gear that doesn't bog down the tractor to much. If this does not help I am not sure what the problem is. Also you might want to invest in a slip clutch if your mower doesn't have one it will save you money in the long run as you will not damage your tractor if it works correctly.
   / Montana 4944
JDEEREKID
Thank you for the info.
   / Montana 4944 #4
I am not familiar with the 4944, however, I have a 4940. On my machine there are two choices for pto engagement; independent and manual. I think that the manual setting engages or disengages as you engage or disengage the clutch, where the independent setting is independent of the clutch. I personally have approximately 1000 hours on my machine, and a lot of those hours have been brush hogging with my 6' mower. I always choose the independent setting, and engage the pto at idling rpm's. This should alleviate your problem. I would look into getting a slip clutch if I were you. It protects your machine without having to climb off and install another shear pin.
   / Montana 4944 #5
I bet you have grade 2 shear bolts. Use grade 5 and you will be good. Don't use any more than grade 5.
Maka
   / Montana 4944 #6
We have a customer with a 5740 who had the same problem. Turns out that there was an update for the tractor (covered by warranty) to engage the pto a bit slower. Some don't need the update, depending on what they're doing with the tractor. Not sure how this would compare to a 4944
   / Montana 4944
Thank you all for your input.
capt windmill
   / Montana 4944 #8
Yes, but that is not applicable to the 4944. It is simply to soft a shear pin using a grade 2 bolt. Grade 5 will fix this I am confident as we see this all the time with customers who buy a new mower. Factory sends grade 2.
When we sell a mower we send with grade 5 (we sell mostly slip clutch anyway) to avoid this for our customers.
Thanks,
Maka
   / Montana 4944 #9
Hi Maka, Is it true about an update on the 5740C PTO? I have complained for years about the force that my tractor engages. The only way I guit shearing pins was to dump the loader valve into bypass while engaging the PTO. I did trade up to a six foot brush hog with slip clutch. It will even mark and dent the grade 8 bolts the clutch is mounted with. I just had another discussion with my dealer several weeks before my tractor went out of warrenty about this subject. That was in early May and still have not heard anything back as yet. Now my machine is off the warrenty, I suppose that will be the end of it. I am not knocking the tractor. This is one awesome machine for the size of it. I use it mostly for bringing logs out of the woods. I do a firewood business on the side. With a 2000 lb. plus counterweight on the 3 pt., I carry 3 - 4 12' logs at a time. I mow and bale hay on about 7 acres also. I dig shale out of my woods to maintain my drive too. Let me know about the PTO issue.
Thanks,
Jim T.
   / Montana 4944 #10
YES there is an update for the PTO. We are a Montana dealer as well and we've crossed that bridge already. Numerous times.
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2002 International 9200i Truck (A52748)
2002 International...
2021 TAKEUCHI TL8R2 SKID STEER (A51246)
2021 TAKEUCHI...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
2018 INTERNATIONAL MA025 (A52472)
2018 INTERNATIONAL...
