Montana 5740 stuck in gear
   / Montana 5740 stuck in gear #1
Troylequerica
Sealy TX
Montana
I have a Montana 5740 that is tuck in gear. the linkage is in second and shifter is in third. Can't get it out. Not much of a mechanic but have common scenes and access to tools and help. Any ideas from you folk would be awesome. Thanks in advance
Since I'm not getting much feedback, does anyone know where to get a manual for the tractor?
   / Montana 5740 stuck in gear #3
troy,
I have a 5740C that I bought back in 2005. The problem you are having is common and really no big deal. It happens with my tractor about once a year at least. The owners manual states that when shifting gears on your tractor that you should do it slowly and go through the H without speed shifting, in plain words. The fix is simple since all it is is that the gear linkage has gotten hung up. Look in from the passengers side, immediately under your cab and you can look in one of the frames holes and see the linkage hung up. Just use a piece is PVC pipe, a shortened broom handle, or whatever you have and reach into where the linkage is and tape the hung up linkage lightly so it is knocked off the other linkage and falls back to where it belongs, along side the other linkage, Oh and keep the piece of whatever you used to tap the linkage because you.ll be using it again, I promise you!! Great tractor though!!
   / Montana 5740 stuck in gear #4
Yes I have had the same issue but have been able to free it up by forcing the shifter from inside the cab. This has happened more than once.
71053 (A49346)
71053 (A49346)
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2008 FORD F-750 (A50854)
2008 FORD F-750...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
