montana farmtrac weight
   / montana farmtrac weight #1
huckie
Bronze Member
Downeast Maine
kubota L3240 dt
can anyone tell me why if the 360 and 3840 are the same tractor the listed net weight is 400+ lbs different?
   / montana farmtrac weight #2
One of the weights must be incorrect...the tractor is the same. to mee it looks more like a 3000lb tractor than a 3500lb tractor. Comparable size to CK30 Kioti also a bit over 3000lbs. maybe Montana is shipping filled tires or quoting a shiping weight including crate, although I doubt the crates are that heavy....
   / montana farmtrac weight #3
3418lbs is the weight. The Farmtrac site is a typo.
Maka
2002 KENWORTH W900 TRI AXLE (A52472)
2002 KENWORTH W900...
TITAN - SET OF 18.4R46 NEW AG TIRES (A52748)
TITAN - SET OF...
2018 Land Rover Range Rover Supercharged 4WD SUV (A50324)
2018 Land Rover...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A52748)
2021 NEW HOLLAND...
2019 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2019 Ford F-450...
