Price Check Montana T2334 (aka TYM T233HST)
   / Montana T2334 (aka TYM T233HST) #1
sdiver78
SD
Searching
Hi all. Looking to purchased a used 2007 Montana (TYM built) T2334 ~200 hrs on it. Seems like a clean machine. Has FEL and frame mount backhoe. No leaks or issues other then rpm tach is out of calibration. Looking to spend 13k on the setup. Any advice, tractor, price or otherwise? Or should I spend a few grand more (less the BH) and go new LS or TYM? Sorry, I did cross-post this in the Montana forum also.
   / Montana T2334 (aka TYM T233HST) #2
I think the price might be a little high for that machine in SD even with the backhoe. I'd say 12k would be more in the range I would be comfortable with if it were me. Do you have any TYM dealers up there that will service it? I assume warranty is gone by now? There are some small issues like muffler, brake switch, loosed frame bolts, etc... that you should become familiar with (check out the forum). There are also couple potential serious issues such as the design of the drive shafts that you should check out beforehand and accommodate for in the pricing.
Thanks for the comment. Will have to research those issue further.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A52472)
2008 V.E...
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
1995 Chevrolet K2500 Pickup Truck, VIN # 1GCGK29F2SE237154 (A51572)
1995 Chevrolet...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2009 Pontiac G6 Passenger Car (A51694)
2009 Pontiac G6...
