more power
   / more power #1
dylan
ottawa, canada
Toolcat B series
I was driving a friends truck last weekend and was amazed at the power he got from installing aftermarket air filters and a large exhaust. He also had an onboard computer with different power levels.
Is this something that can be done with the toolcat or a really bad idea?
thanks
   / more power #2
The computer is the key; that's where the increased fuel and boost comes from.
You can get somebody to "turn up" your pump for similar results; but I don't think it would be a great idea for reliability.
   / more power #3
The computer does not control the engine so to speak. It does monitor systems but it doesn't actually control much. Adjustments to the injection pump are possible but are tough to accomplish. Do not mess with the air intake system because a mistake can cost you an engine.
There's not much you can do with the piece apart from pump/injector mods and I don't know where you'd source those pieces.
   / more power #4
Dylan,
Why do you need more power for your Toolcat...?
Steve
   / more power
I've noticed that the tc struggles a bit with some of my attachments and it can bog while pushing large piles etc. I don't loose traction, just run out of power.
On another note, I'm sure high flow would make a difference with my snow blower attachment as it does not blow nearly as well as some of my other snowblowers that are mounted on tractors.
2008 Ford Taurus Sedan (A50860)
2008 Ford Taurus...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2024 iDrive TDS-2010H Pro Jack M2 Electric Trailer Jack System (A48081)
2024 iDrive...
John Deere HX15 Flex Wing Rotary Cutter (A50860)
John Deere HX15...
2012 Jeep Grand Cherokee 4x4 SUV (A48082)
2012 Jeep Grand...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
